dvd player or discs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by spocktra, Mar 21, 2005.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    I have a tosh 340e and recently it has been suffering from occasional pixelation or blocking.Could this be the faulty discs or is it more likely to be the player.I know the drives on these machines are of poor quality but this has only started happening since i put the m/r remote hack in.It has only affected 2 discs so far.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Are you saying this problem only just started to affect these discs or are these new discs you didn't play before?
    Could be just poor quality transfers with a low bit-rate.
  3. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    The incredibles r2 was one of the discs.K- pax the other.
  4. deanym
    deanym
    May 29, 2004
    1,789
    +141
    I'd suggest trying the two discs on another player, if they work it then possibly a new player is in order. If you have a games console try the discs out on that.
