DVD Player Limits Play Of MPEG2 Files
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Smasher, Apr 5, 2005.
  1. Smasher
    Smasher
    Don't know if this in the right place but here goes.
    Anyone able to shed any light on this:-
    I have been recording satellite feeds onto the HDD of my PC. All works fine and can play back the MPEG2 files no problem. If I then burn this file to DVD and try to watch it in my DVD player it will only play the first 50 minutes of the file. This has proven very frustrating whilst trying to watch a movie of 1.5 - 2 hours long. All the file is there as I can watch it from the DVD on my PC with PowerDVD, etc. It's just the DVD player only see's the first 50 mins.
    The DVD player in question is a Yamaha DVDS540 which I otherwise have no problem with.
    If I convert the file to VOB/IFO structure for full DVD compliance the DVD player plays it no problem - it's just I didn't really want to do this for every movie I record.
    I could understand the DVD player not recognising the file at all, but to play the first 50mins only is really bugging me.
    Anyone able to help?
    Smasher
  2. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    The files are too big, anything about 2gb is likely to cause problems. You need to either split the mpegs or carry on authoring them to VOB, authored DVD's split into 1gb chunks I suggest you do the same. Definitely stay below 2gb chunks.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Does sound reasonable that a DVD player would have trouble with files larger than 1gig since vob files max out around that figure and there must be a reason beyond easier navigation/searching.
    Unless you have a really slow PC mastering a DVD from a dvd spec mpegII file isn't that time consuming and of course lets you include chapters and menus if required.
