DVD player for Sony 10HT
Discussion in 'Projectors, Screens & Video Processors' started by slingshot, Jul 23, 2001.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I've just posted a request for recommendations for a new DVD player on the DVD section, but just in case here's the spec I'm looking at :-
    Multi-region (who does the best conversions ?).
    Progressive scan (on PAL and NTSC ????).
    DVD audio (maybe worth it).
    I have a decent CD player so CD quality is not important.
    Upto about 1K, any one any ideas ? Should I think about a cheaper DVD without progressive scan (especially since most my stuff is R2) and maybe add an Iscan or similar later ?
    Since I posted the original I noticed that a Denon 2800 could be upgraded to PAL progressive so it may be worth considering.
    Anyway if anyone can offer me a pointer in the right direction.
    Slingshot
  2. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Pioneer 737 works well with NTSC progressive.
    Toshiba 900 DVD-A player is very nice, picture and sound are great.
    Given the option though I would use an Iscan and have the ability to scale VHS, laser, Sat , etc. Also picture smoothness is better on the Iscan than the Pioneer.
    I dont know about the Denon 2800.
