DVD player for a 480I DVI projector
Discussion in 'Blu-ray & DVD Players & Recorders' started by coastersteve, Jan 27, 2004.
  1. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Could anyone recommend a DVD player which has DVI output that can do 480I as my pj doesn't recognise Progressive signals.
    I was hoping something like the Yamakawa would do the job but I haven't got a clue.
    Currently I'm using a Limit 9000SE to ProV+ then PJ. Whilst the results are OK they're not jaw dropping.
    Hope someone can help
    Steve
  2. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Does no one know a DVD player that outputs 800X600 via DVI? :confused:
  3. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    HeHe. Yes, the HD935 when you select native format on PAL discs, I'm assuming this is a bug...
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,200
    +3,030
    JohnWH,
    Are you asying that your DVD will output 576i on it's DVI port?
    What display device do you have that can show a 576i DVI signal?
    coaster: 480i and 576i are not supposed to be supported by DVI. 480P and above is. I do not know which DVD players can output PC resolutions via DVI.
    Hope this is some use,
    Gordon
  5. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    No, I'm having problems getting the player to push out PAL material in native prog res from the DVI port, goes to 800x600 for some reason, gets 576p from the component out though. This only a minor issue as the 720p output is very good. I'm using a Sharp Z200 projector.
    Cheers,
    John.
