Dvd Player Fell Off Roof
Discussion in 'Video Streaming Boxes & Services' started by jerry03arc, May 5, 2005.
  1. jerry03arc
    jerry03arc
    My wife and I recently purcahsed an 2003 GMC Envoy that had an aftermarket DVD system installed in it. It apparently was not isntalled properly as it worked itself loose and with a little tap fell down. I am looking for the best way to reinstall it.
    The car does have a factory install DVD option in the same location in the roof where this one is installed so there is already a reinforced plastic backing plate to install it on, but it was just screwed in with machine screws with no locking washers or anything. I don't want to just screw it back in because I will most likely have the same problem again. Can I use a butterfly nuts or some sort of modified drywall anchors, or is there something better I can use?
    Help!
    Here is a pic of the unit if it helps
    http://www.opela.net/public/envoydv1.jpg
  2. jerry03arc
    jerry03arc
    40 views and no one can tell me how to secure a DVD player to the roof of a car???
  3. Boy Lex
    Boy Lex
    Sorry, but there are probably a million and one ways to do it! Cable ties, magnets, velcro, gaffa tape, threaded screws. I'd say it all depends on what the mount is like? Use a bit of inginuity and you should be able to come up with an answer yourself. Why not come up with a solution and them stap some sort of bungee to keep in from dropping (and breaking). Then you can drive it around a bit and see if your solution holds and remove the bungee when you are confident it's working.
