dvd player connected to home cinema
Discussion in 'Blu-ray & DVD Players & Recorders' started by BIGMAX, Mar 17, 2005.
  1. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Whilst I decide on a new amp and speakers, I need to run my hdmi dvd player through my home cinema system so I can get the hdmi picture on tv and get dolby digital/dts out of the home cinema. I have connected the two with an optical cable but the display on the home cinema says pro logic and I can't seem to get the dd sound out.
    Any suggestions ?
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    is the audio out set to pmc?
  3. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Yes and pmc is coming up in the corner of the HC display.
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    pmc is only prologic...should be set to 5.1 or it may just say original, or digital
  5. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Hi Mep,
    Sorry to be a thicko but I trust you can change that setting on the dvd player which has the disc or is there a setting on the Home cinema to do also.
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it's normally in audio set up in the dvd menus, the home cinema 'should' automatically detect the signal type being sent to it.
  7. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Cheers mate, I'll try that later.
    Thanks for your time.
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    no worries, hope it gets it sorted (which dvd player is it btw?)
  9. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Hi Mep,
    Sorted that out last night thanks to you. The dvd player is the samsung hd945 which is cheap and cheerful but I played around with the settings on the tv last night and the picture I got was fantastic.
    Cheers again.
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    good stuff mate...just saw you had it sorted in the plasma forum
