DVD player channels ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by renier8, Aug 8, 2005.
  1. renier8
    renier8
    May 17, 2005
    15
    4
    Hello
    Some advice would be greatly appreciated. I have an amp that handles all my channels and stuff. It is setup to 5.1.
    Now recently I went into my DVD player menu, and saw that it too features 5.1 channels.
    So my question is this: What settings do I use on what component ? Should both DVD and AMP be set to 5.1 ? etc.
    Many thanks
    Renier
  2. wannabeav
    wannabeav
    Hi, Check with the manual but the digital output should just send the full 5.1 soundtrack and the amp will then decode / process. You can then provide distances, size, config, etc on the amp. The other settings on the dvd menu should relate to the analogue outputs. If you're just using a coax / optical out to the amp dont worry about them.
  3. renier8
    renier8
    May 17, 2005
    15
    4
    Many thanks for that.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The 5.1 setting in the player is probably related to the 5.1 output (on-board decoder).
    Since you have an AV amp you don't need to bother with that, it's a kind of redundant and only required if you have an old amp that has a 5.1 (analog) input but no DD/DTS decoding.
