dvd player change
Discussion in 'Blu-ray & DVD Players & Recorders' started by oxygenuk, Dec 4, 2004.
  1. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    Thinking of sending my current sony dvp-ns585p back because of the problems im having with it
    thinking of gettina pioneer dv575 if i decide to, question does the pio 575 have sound decodings the ns585 has like can trasmit all dts and dolby formats like matrix 6.1 ex 6.1 neo 6.1 can u manually switch which of those dts dolby sound formats while playing dvd? thats what u can currently do with the ns585 which i think is very good feature
    advice and help needed here, so please do
    :D
  2. nwgarratt
    nwgarratt
    May 5, 2002
    26,446
    +2,873
    If a player can output DD and DTS formats, shouldn't it do the 6.1 versions as well? If you can't switch audio tracks when playing a DVD, then it is the DVD causing it and not the player.
    What problems are you having with the 585. I was going to get a Pioneer 575 and opted for the 585. So far, I am delighted with it.
  3. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    well its not playing some discs and will play on other dvd player makes a quiet tickin sound while playing cd's an makes a loud scanning noise with some dvds
    if u have a 585 u shud no wat im talkin about changing between dd and dts formats you know that button on thr remote control that looks like 3 ckircles, welll when you press that u can select which dd or dts or audio commentary u can have playing the disc, im wondering if you casn do that with the pio 575..
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,446
    +2,873
    Some discs don't allow switching of the audio while running the film. It is a PUO (prohited user operation). The only way to change is to go back to the menu. It is a pain and serves no purpose. If the disc works allows switching in the NS585, then it should work the same in all players.
    I only play DVD's in my NS585 and so far (just like NS900) is has played everything. It is also very quite and I cannot hear it in operation.
