DVD player aspect problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nippy_Kangaroo, Oct 17, 2004.
  1. Nippy_Kangaroo
    Nippy_Kangaroo
    Hi, :hiya:
    I'm having trouble setting up a celestion dvd300 player with my panny plasma via component input progressive scan. Everytime I change my dvd players settings to widescreen, certain parts of movies the picture starts jumping or a black bar starts rolling up and down then it says no input for a few seconds and goes back to normal but when i change the dvd player back to the standard 4:3 aspect it works fine (i would leave on 4:3 setting on if it wasnt for the massive boarders)
    can anyone help or do you think i should send it back??
    thanx
