DVD Player and External DAC
Discussion in 'Blu-ray & DVD Players & Recorders' started by Falp, Dec 10, 2004.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Hi! :)
    I'm planning to buy a new DVD Player to be used as my music source for a new system.
    Since playing music in a DVD player even using the AV Receiver's DACs is not the same as a dedicated CD player I'm planning to buy a good used External DAC.
    Question: is it worth it? As anybody tried this?
  2. Bails
    Bails
    Oct 15, 2003
    203
    +3
    Are you planning to also use the dvd player to play video dvds? I have a dvd player (Marantz DV-8400) with an external DAC (Bel Canto DAC2). The problem is that I want the DAC to process two-channel stereo via a digital output for cd playback but would also want to output to my av receiver for movies (otherwise the movie soundtrack would go through the DAC and end up in 2 channels). I don't think this is actually possible, and am looking at a separate cd player to use as a transport.
  3. joust
    joust
    Sep 4, 2002
    942
    28
    Basildon, Essex
    +55
    Hi Falp,
    Head on into the 2channel area on the forums. There you will find quite a bit of information on the very subject! As for me, yes I have an external DAC (a Tag DAC20) being fed from a Pioneer 575, and it sounds good to me!!!!
    Joust
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    That's what I want... plannig to buy a marantz DV6400 or 6500 and use it for movies and musica.
    For stereo only using an external DAC and an AVReceiver analogue input Direct Mode.
    For surround the usual digital AVReceiver input...
    So i'ts worth it?
