DVD player advice
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ian Carter, Mar 22, 2003.
  1. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    I went into Richer sounds today with the intention of coming out with a Toshiba 220 multi region. The keen sales guy said that the Tosh was 'OK' but was pushing me towards the Limit 9900SE. saying it has Progressive scan on PAL - is that right and will it be of any benefit to me having a normal Philips 32" 100hz set.
    Is it really better or is the commission just higher?
    I realy dont know which player upto £150 to go for!!!!
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I would go for the Tosh. They make cracking DVD players. The 220 is great model and I pressume region free at richer.
    yes, the limit is progressive enabled but have you got either
    a component in TV that supports progressive scan
    a projector
    or are you going to get either?
    If no, go for the Tosh. It willdeliver a superb RGB or s-video picture for you.
    Hope this helps.
    Captain benefit
  3. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Thanks - I had decided on the tosh over the pioneer 350/454 already but they threw a spanner in the works with the other suggestion.
