Quantcast
DVD Player Advice wanted
MATT JENNER
I have at the moment a Pioneer DVD 737, i am very happy with it, but i really want multi region,
So what player can you recommend up to 500.00 that has the following
Component,
multi region capability,
dts,dd,sacd,
I currently connect it to my Crt Projector via compnoent out to bnc , i am currently having a wire made up that utilises the rgb as well, so it will be rgb sync and component into the projector,
regards
Matt
"if it works leave it alone"
