DVD playback - Xbox (Standard) XBMC @ 720p Vs Philips DVP-5960 @ 720p
Discussion in 'Blu-ray & DVD Players & Recorders' started by BiffBoy, Sep 19, 2007.
  1. BiffBoy
    BiffBoy
    Aug 1, 2007
    1,330
    +99
    Having just purchased a new Mirai 32¨ LCD I am using my standard Xbox & XBMC to upscale DVD´s to 720p (over component) but I am wondering how much better they will look using a Philips DVP-5960 upscaled to 720p over HDMI.
    Has anyone (or could anyone) do a comparison and let me know wether it would be worth spending the extra £40 ish for the Philips DVP-5960.
    Thanks for the help guys
    Steve
  2. plasmahal
    plasmahal
    May 3, 2007
    +3
    Have you got the new xbox elite system ?
    My xbox 360 over component will only upscale to 576p, which is what the design spec will allow.
    I assume you mean xbox media centre when you quote xbmc ?
  3. BiffBoy
    BiffBoy
    Aug 1, 2007
    1,330
    +99
    yep, as mentioned in the title and desciption I using the standard (older) xbox and I do mean Xbox Media Center (XBMC).
    Was wondering if the upscaling would be much better on the Phillips? As it´s only £40 ish I could be pursuaded and then I will be saving up to build a HTPC (which I know whill be better again).
    Waht to do, waht to do :suicide:
  4. plasmahal
    plasmahal
    May 3, 2007
    +3
    I would suggest getting a seperate upscaling dvd player.
    Your choice of player is dependent on your budget.
    For me, I recently bought a sumvision phoenix upscaler for £25 and once i got past the setup issues it gives very good performance and has hdmi output at 1080i, a usb reader which you can play divx films from aswell as the dvd.
    Cheap - yes, functional - yes, good picture - yes.
    Do what you know best.
    here's a link to another thread i started about this player:
    http://www.avforums.com/forums/showthread.php?t=622846
