DVD Playback stopped working in MCE....Help!
Discussion in 'Microsoft Windows' started by PannyAdams, Apr 16, 2005.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    For no reason, my MCE seems to have just started to refuse to playback DVDs. I just get a black screen - but the transit bar comes up and indicates there's nothing to play, The same happens with DVDs ripped to the Hard drive through My Movies, but DivX play fine.....Arrrrggghhh! Help anyone?
  2. DaveP
    DaveP
    Sounds like a Codec problem to me. Have you run DECCHECK.EXE to see if you are running the correct one?
    Dave
  3. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    I've run Deccheck.exe and the Codecs are all there.
    I managed to get one of the films playing this afternoon - so the Codecs are definitely there, when I then seleceted another film to play it just resumed the previous one again! It does the same if I'm playing audio and select a movie it just takes me to the now playting audio screen?
    It appears to be an MCE or windows Media Player problem - anyone had anything like it?
    I'd just got everything working -arrgghhh!
  4. lisag
    lisag
    Jul 14, 2004
    5,990
    Essex
    +397
    Oh dear, this sounds most odd, I haven't got a solution I'm afraid, just some sympathy!
    The things I might try include,
    Uninstalling and re-installing codecs,
    Check for updates on all drivers, software, codecs etc.,
    Uninstalling and re-installing any plug-ins (My Movies?)
    Windows Updates
    Virus / Spyware scan
    Looking for help on the green button, or xpmce,
    Clean install of MCE (argh)
    lisa
    :rolleyes:
  5. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Hi thanks for the post.....
    Reinstalling MyMovies seems to have fixed it - dodgy problem - happened after I added a load of movies to the Database. Now I've got to re-add all my movies, still quicker than a re-install.
  6. lisag
    lisag
    Jul 14, 2004
    5,990
    Essex
    +397
    Good news!
    You can manually back up the My Movies database, or if it was a fairly recent version the databse may still be in the My Movies install folder. There has been some new releases of My Movies recently, version 1.23 is the current one, this is a good link here
