DVD Playback Problems
Discussion in 'Desktop & Laptop Computers Forum' started by ajbeech, Jan 8, 2003.
  1. ajbeech
    ajbeech
    Jan 7, 2003
    57
    Hi All,
    Can anyone offer any advice?
    I've recently been turning my PC into a mini home cinema setup. The basic spec of my PC is as follows:
    ABit KT-7A Motherboard + latest VIA drivers
    512 mb RAM
    Windows XP Pro
    Creative Geforce4 Ti4600 video card
    Creative Audigy2 Platinum sound card
    Creative Inspire 6700 Speakers (6.1 surround)
    I use PowerDVD XP 4.0 as the DVD player.
    The DVD player is set to DMA
    The problem I am experiencing is somewhat choppy video playback - its watachable, but looks bad when compared to my standalone DVD player. My PC setup should be more than capable of decoding DVDs and I can seem to locate the problem.
    I have no other problems with the PC - it runs anything thown at it, including the latest 3D games (with all settings maxed out).
    I intend to try another software player this evening to see if it makes a difference, but I'd be grateful to hear from anyone who has had similar problems and solutions used!
    Thanks,
    Andrew
  2. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    Hmm, no-one replied to this post, i found it when searching for something so if i am repeating something please excuse me.
    Switch the DVD-rom drive off of DMA, i know this sounds strange. You would think that DMA would improve the scenario.
    Try it, disable DMA.
    Simplest way to do this.
    Hit 'windows key'+ 'Pause break' (its the system control panel)
    select device manager
    select cd-rom
    select your DVD-Rom drive
    hit properties
    select settings
    unselect DMA
    try it out.
    enjoy.
  3. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Firstly I would think that DMA should be switched on and in fact I think that this is automatically applied for windows XP anyway
    Try changing your refresh rate to 75hrz for Pal DVDs and 72Hrz for NTSC
    Conor
