DVD Playback problem
Discussion in 'Desktop & Laptop Computers Forum' started by phenom2003, Aug 20, 2003.
  1. phenom2003
    phenom2003
    When I play a dvd the video and audio is choppy. The windows troubleshooter tells me to turn on dma under the IDE controller, however the device stays in PIO? mode, and doesn't switch to dma even though use dma where avaliable is selected. DVD playback used to work fine, can anybody offer any help or suggestions? Any help will be greatly appreciated.
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,420
    Surrey. UK.
    +2,085
    Installed any new hardware or software recently?
    Gary.
  3. phenom2003
    phenom2003
    Its been like this a while, so Im not sure whats been added since.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    what Operating System are you using ? What chipset is on the motherboard ? - as these problems quite often occur on VIA chipsets .
  5. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Make sure the drive is set to DMA Mode 4 or 5 in the BIOS settings
  6. phenom2003
    phenom2003
    I cant change it to dma mode in the bios, and windows wont let me change it, as I have already selected use dma if avaliable and it remains in pio mode.
    The motherboard details as described by the belarc advisor are:
    Board: NEC COMPUTERS INTERNATIONAL SiS651 1.x
    Bus Clock: 133 megahertz
    BIOS: American Megatrends Inc. 2.0H 08/22/2002
    The manual that came with the system called the motherboard a columbia 2.
    The system is a packard bell imedia 5094.
    Its running Windows XP Home Edition (build 2600).
    Does this help at all?
  7. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    I would go to the Packard Bell website and look for the SIS IDE bus mastering patch - it would be advisable to try there first. If it is not there then I would look on the SIS website SIS for that driver. I think the file you are looking for is SiSide41.exe or something like that (there may be a later version now). This file should sort out bus mastering.
    Before you go ahead and install I would create a system restore point in XP and double check that this is the correct driver for your chipset - in other words don't blame me ;) :D
