dvd playback on xbox
Discussion in 'Xbox Forums' started by mcmullanbrush, May 6, 2002.
  1. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    a friend of mine has an xbox bought in england. he believes that if he buys the dvd enabling kit from the usa it will make his xbox a region 1 dvd player. does anyone know if this is correct?
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    No, it will not work.
    Either the remote receivers are identical and it will not make a difference at all - or they have different ID's, in which case a PAL Xbox will refuse to work with a U.S. bought DVD kit. All DVD drivers and region settings are in the Xbox itself.
    Edit: I might be wrong.
  3. cerberus
    cerberus
    I think someone (maybe museum steve) has found that id did work. From memory though if you use a US kit you can't then get a UK kit and swap between the two, something to do with the DVD kit locking the xbox to that region. You might try a search to see if you can find that thread, I think it was a thread that museum steve started.
    Take a look at this. Don't hold your breath for it though, in the last month play have changed the release date of this more times than I have changed my underwear (but that's a different story :blush: ). I have also heard about a DVD kit that lets you change the region using the controller, that all I've heard but it sounds interesting!!!
    Tim
  4. Guest
    Just to confirm it will work, but cerberus is also correct in saying it will lock the box in this region.
  5. museumsteve
    museumsteve
    Jan 28, 2001
    8,007
    4
    Nth Hampshire
    +1,109
    I spoke to Datel last week and they tell me the Region X for Xbox will be out 1st week of June..:)
  6. cerberus
    cerberus
    Are they the people that make the Action Replay as well? I've noticed that the same is happening with that - the release date changing, that is.
    Tim
  7. Family Guy
    Family Guy
    I read in a magazine that the region will lock onto the first disc played in DVD mode. This was in X Gamer mag last month.
    I checked the DVD controller recently, and the region code (world wita a 2 over it) was on that, so it seems that article was cack and it is the controller that locks the region.
