DVD play In USA
Discussion in 'Blu-ray & DVD Players & Recorders' started by niccam, Jul 19, 2005.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi just a quick question will a DVD burned in the UK play in the USA in a multi-region DVD player or will I have to change it to NTSC and how can you do the latter if I have to . Thanks for any info
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Doesn't matter if the player in the US is multi-region or not, as any recordings you make will be region free. But PAL/NTSC does matter. Generally speaking a set top DVD player in the US will not play a PAL DVD - though some will. They will be able to play them on a PC.
    If you want to be sure they can play the disc on a set top DVD player, you would need to convert it to NTSC. This can be done on a PC with various editing software, it can't be done directly from a DVD recorder.
    Mark
  3. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks redsox I was afraid you would say that I would have to change to NTSC .Are you 100% sure that it will play in the computer in the USA?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    A few do - most don't.
    niccam - yes the PC will be able to play PAL discs - all the major software DVD players support PAL (WinDVD, PowerDVD etc).
