DVD patch
Discussion in 'Blu-ray & DVD Players & Recorders' started by Woolybully, May 6, 2002.
  1. Woolybully
    Woolybully
    May 6, 2002
    267
    Bradford
    +11
    Does any of you guys know where I can download a patch for my
    DVD ROM (Toshiba) to play all regions? of course it used to be multi-region for a time, but once you play a certain region so many times it sticks on that so now I'm region 2 only.
    Any Ideas?:confused:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,160
    Warwick
    +3,006
    I suggest downloading DVD genie. This will look at your setup and tell you what you need to make it multi-region. Also if you do a search on Altavista or similar for dvd-rom hacks then a few sites will be highlighted.
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
