DVD out via Co-Ax? Help needed please
Discussion in 'Blu-ray & DVD Players & Recorders' started by hollie.weimeran, Dec 13, 2003.
  1. hollie.weimeran
    hollie.weimeran
    I would like to install a DVD player in the bedroom to replace an old VCR. Problem is the VCR is quite a way from the tv and the wires are buried in the wall so a scart conection is impossible. Is there any way of converting the scart signal in order to get it onto a co-ax connection?:confused:
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I'm sure anything is possible but I'm more sure you wouldn't want to.
  3. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    An RF modulator would work, but as Weirdfish pointed out the results might not be that great.
  4. hollie.weimeran
    hollie.weimeran
    Thanks guys - looks like i'm stuck with the vcr unti i redecorate!
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,437
    WEST MIDLANDS
    +1,411
    Have you tried looping the DVD through the VCR ?
    It doesn`t always work as sometimes it triggers the macrovision on the vcr but its worth a try !
