DVD or PC
Discussion in 'Projectors, Screens & Video Processors' started by skimber, Dec 1, 2001.
  1. skimber
    skimber
    Dec 1, 2001
    205
    19
    I'm curently awaiting delivery of a Philips UGO s-lite and was wondering what the best source for DVD's would be...
    Samsung 709 or a PC with DVD drive and s-video out. If the PC route is best for picture quality then how do I go about getting DTS sound into my hifi (Kenwood series 21, SE-A951S). At the moment i use the digital audio output on the back of my DVD into the digital input on the hifi. so how do i get a digital DTS signal out of a pc?
    Simon
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,621
    7
    167
    Birmingham, UK
    +10,500
    Not familiar with that projector. It *is* datagrade, isn't it? It needs to be able to do [email protected] as a minimum.
    For Dolby Digital and DTS out, you just need a sound card like the Fortissimo II. Optical output for about £30.
  3. Dangerous
    Dangerous
    Simon
    I'm glad you have ask this question as I am considering upgrading to a progressive scan dvd player and as I was trawling through past posts I notice Spectre commented that "It many not be quite the most user friendly option, but if picture quality is paramount, then you should think about a HCPC. It will wipe the floor with all the players mentioned". As I am not familiar the the concept of using a computer to deliver audio visual signals to my 10HT could someone enlighten me as to the best specification for such a computer. Also the pros and cons.
    Dave
  4. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,621
    7
    167
    Birmingham, UK
    +10,500
    Simon and Dave - this thread really belongs in the HCPC forum, so I'm going to move it there shortly.
    Mean time have a look through previous threads in that forum for more information.
  5. skimber
    skimber
    Dec 1, 2001
    205
    19
    i don't agree! :)
    my main original question was what would be the best source for my projector, Player or PC. the sound question was just an afterthought!
  6. GaryG
    GaryG
    PC!
  7. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,621
    7
    167
    Birmingham, UK
    +10,500
    Simon, by the way, the way to connect up a PC for the best pictures is via the VGA output to RGB input of the projector.
    NOT s-video as you first suggested. Taking the s-video output (i.e. interlaced as opposed to progressive scan) does not have any performance advantages over a normal player.
    Which is why it is important to know from the outset if the Philips can take [email protected] computer signal beore you start down the HCPC route.
  8. skimber
    skimber
    Dec 1, 2001
    205
    19
    Cheers! On the specs it says "Computer Inputs: 15pin Sub"... is that what i need? :confused:
    Simon
