dvd novice burner--help please
Discussion in 'Desktop & Laptop Computers Forum' started by barrykil, Jan 13, 2005.
  1. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    need some help/advice,novice with computers so here goes, just installed a nec 3520 burner and got a copy of nero (oem suite 3) if i try to copy a dvd straight to disc i get "disc copy protected" on the screen, is there something i can do or should have done any advice would be most welcome....
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    You need what's called a DVD 'ripper', something that can break the copy-protection .. in the case of DVDs they're encrypted, so you need something like DVD Decrpyter or DVD Shrink, depending on what you want to do. DVD Shrink is probably most useful to most people, DVD Decrypter has one or two neat features like ISO imaging but that's more specialised.
    Plenty of discussion around here about DVD Shrink, plug that into "Search" and you'll come up with info, you can download it from here.
    The full version of Nero includes Recode which is a tarted-up version of Shrink, the guy who wrote Shrink sold it to Ahead, but Shrink is more than adequate.
  3. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    thanks for that :thumbsup:
  4. simon100
    simon100
    Nov 2, 2004
    318
    +11
    I have DVDShrink and it works very well, compressing the DVD down to size. It might take some time, but it is worth it. It also integrates seamlessly with Nero so that you can leave the PC whilst it does the job.
  5. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    just downloaded dvdshrink32setup is that the one i should use?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
  7. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    thanks :smashin:
  8. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    on average how long does it take to burn a movie including encoding?
  9. themoid
    themoid
    Oct 23, 2001
    835
    Staffs
    +25
    depends on the quality of the encode. several hours up several days - the kind of thing you leave running while you are asleep :D
    the actual burning part isn't too long at all, i guess 30 mins. and if using dvdshrink that is pretty quick.
  10. Dean
    Dean
    Jun 20, 2003
    2,649
    London
    +178
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Sorry Dean, DVD Shrink is free, does the CSS decryption and needs only a few 'clicks' to rip the entire DVD, barely much more effort to select just the main movie etc.
    Notice Shrink isn't in their comparison chart. IMHO $59.95 is extortionate for what that can do, even Nero Recode which comes as part of the Nero Ultimate package (costing not much more) out-does that package in terms of features.
  12. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    did my first disc today from start -finish about 40 min is that about normal, used dvdshrink
  13. watersa@ntlworl
    watersa@ntlworl
    Depends what your copying?
    Generally I manage around 25min at 8x speed with a NEC 3520 using DVDFAB
    I 've got a AMD2600 skt A & i gig of Ram. I doubt there is much difference in software apart from I bought mine?
    I have since hacked my registry for the activation key tho ;-)
  14. barrykil
    barrykil
    Jan 17, 2002
    2,370
    48
    +26
    thanks all :smashin:
