DVD Menus
Discussion in 'Blu-ray & DVD Players & Recorders' started by nunew33, Aug 15, 2004.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Is it possible to create 16:9 menus? Cant seem to do it in TMPGenc DVD author
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,033
    Warwick
    +2,897
    Not as such - but there is a bit of a workaround. In your graphics create a 16:9 formatted menu background. When you load this into TMPG Enc Author this will be 'stretched' into 4:3 format. Author the project as normal but before burning to disk use InfoEdit to add the widescreen flag for the menu.
    Obviously your menu Text will be slightly deformed (but you can always add this direct to the menu background) as will your thumbnails but cunning menu design can normally mitigate that.
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Info edit?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    22,033
    Warwick
    +2,897
    :blush: Sorry typo - IFO Edit which can be found here.
