DVD Media
Discussion in 'Blu-ray & DVD Players & Recorders' started by mulder, Jun 6, 2004.
  1. mulder
    mulder
    Dec 9, 2002
    146
    I have a sony GX3 and I have previously used Zero Defex+rw and Zero Defex+r, Bulkpaq orange DVD-r all have been fine. I thought i would give Ritek discs a try but after reading on another forum that the quality of Ritek manufactured disc has deteriated I am un-sure which disk to go for. the same forum says that Verbatim is good. I was wondering what other forum members use.
    +- Poll
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,186
    +3,037
    I wouldn't use Verbatim. The quality has reduced since they chnaged manufacturers (CMC I believe).
    Grade A Riteks will be fine. These are brands such as Traxdata, Ridisc and Ridata. There Grade B discs such as Aritia have started to show problems after being burned a while ago.
  3. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    I thought only Verbatim's spindle discs were made by CMC? Their jewel case DVD-Rs are still very good quality discs.
  4. WoB
    WoB
    I bought some TDK DV-RW (1-2x) for my GX3 and they work a treat! I had some old datasafe knocking around from a year or two back and they were terrible - very slow in formatting/finalizing. The TDK are very fast in comparison: 10-20 seconds to format and 30 seconds to finalize (in video mode). I bought a box of 10 for around £20 including delivery. Think I got them from here:
    http://www.cd-rmedia.co.uk/cgi-bin2/details.pl?id=tdkdvdrw
    They read fine in my PC and RW compatible players also.
