DVD Media
Discussion in 'Blu-ray & DVD Players & Recorders' started by shane5825, Oct 29, 2003.
  1. shane5825
    shane5825
    I have an older DVD burner Memorex that burns at 2x. most of the media out there now is 4x, can I still burn dvd's using 4x media with a 2x drive? Thank you
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    Yes. All media should be backwards compatible.
  3. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    You should check for a firmware upgrade as 4X media is different from 1-2X media :)
    Can mess up your laser if you dont.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    As I understood it there was/is no risk of damage to DVD+RW drives - only the DVD-RW drives from Pioneer/based on Pioneer technology. Namely:
    Pioneer DVR-7000 (Set-top)
    Pioneer PRV-9000 (Professional DVD recorder)
    Pioneer DVR-A03 PC drive
    Pioneer DVR-103 PC drive
    Pioneer DVR-A04 PC drive
    Pioneer DVR-104 PC drive
    And any OEM variants/rebadged variants
    The only risk with + drives is that there will be wasted media in which case you can then update the firmware (which isn't really something you want to do frequently). Unless you have heard otherwise ted26?
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    Just in an update on this subject - I had a look on the Memorex Website and they had this article on the subject (DVD-R recording):
    http://www.memorexlive.com/data/4xdvdmedia_compatibility0003.pdf
    Mentions the drives I stated above but doesn't say if Memorex units are affected :confused: Not particularly useful! Anyway Shane I would take a look at there website although I can't see any mention of firmware updates for + drives (which I assume yours is):
  6. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    I thought it was the same for all drives rasczak!!
    Could be mistaken :p
    Its worth taking a look on the the links that rasczak has posted while i was typing :laugh:
    Better safe than sorry.
  7. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    Well it seems that the discs are ok and it was a bug in certain drives
    I see no mention of your drive needing any such upgrade :)
