dvd media needed dvd -r
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by SHAUNY, Jan 6, 2004.
  1. SHAUNY
    SHAUNY
    hello i have been using a company called svp to buy my blank dvd - discs but they have run out a the moment
    so 1) do you know of any other cheap companies and 2) any other brands that are compatiable with a pioneer 104 dvd rewriter AND a toshiba sd420e dvd i have been using mainly bulkpaq generation 3 r2 dvd -r and datawrite classic yellow
  2. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    I use either SVP or bigpockets.co.uk.
    Both these sites will state compatibility with your burner. My 105 seems to work Ok with whatever they recommend!
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    I was going to recommend them
    Bit dodgy because if the shop gives the go ahead I start duplicating like mad!
