DVD lip sync problems
Discussion in 'Movie Forum' started by saints, Jul 29, 2004.
  1. saints
    saints
    I just bought a Toshiba 330e Multiregion DVD player and I noticed that speech seems to be just in front of the screen image.
    At first I thought I was going mad so I asked my wife to watch it and she spotted it as well so I took it back and exhanged it for another, but I have exactly the same problem with the second Toshiba, the DVD I am playing is Babylon 5 series 3.
    I was just wondering if this is a common problem with DVD discs or Players or am I just unlucky to have had 2 dodgy players?
  2. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    try the b5 dvd on anothe player if you can. Its more likely the disc than the player in my exprience. Alternatively if you are listening through an amplifier setup there may be a delay option built into the amp for use with projectors etc.
  3. chris110
    chris110
    Jan 10, 2004
    221
    16
    Gloucester, SW England
    I used to have a cheap old DVD player and the exact same thing used to happen. As soon as I changed to a different one it was all fine again :)
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    My kids both have a toshiba 330e multiregion in their bedrooms,never had any problems with lip sync it sounds like a disc problem to me.
    Cheers Gonzo :) .
  5. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Got the B5 set in question and and no lip sync problems.
  6. Marc
    Marc
    Jul 8, 2004
    11,719
    Titchfield
    +1,101
    are you passing the audio through an amp? Perhaps that's causing the sound delay, if you are, try using a regular scart for the video+audio if you can and see if the problem persists. Not that its any sort of solution if you can't use an amp, but worth checking!
  7. captainH
    captainH
    Mar 17, 2004
    901
    63
    Bucks
    +249
    The only discs I have really experience significant lip-sync problems is the Aliens Quadrilogy - a couple of the films with "seamless branching" seem to cause my player problems (Harman Kardon DVD25).
  8. grafzep
    grafzep
    May 25, 2003
    99
    Part of the difficulty is that once you've decided that the lipsync has slipped (assuming we're only talking about a couple of frames) it is extremely difficult to decide that its ok again. If you see what I mean.
    It seems pretty obvious that you should try a selection of discs to see what to blame. If you don't have any video processing in the chain it is more likely to be the disc (the transfer, not your particular disc) than the player
  9. FoxyMulder
    FoxyMulder
  10. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    Where did saints go?
    I'd like to know how he got on.
  11. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Just read Foxy's piece on his website. This was also my experience, which is why I waited almost a year before buying a DVD player. In the early days Pioneer were the biggest offender of the lot with lipsync. Their "1" range including the 717 and 414 as mentioned by Foxy was really troubled by this.
    Pioneer did learn their lesson from this and ensured that they really sorted the firmware problem out before releasing their next "2" range. In fact I remember a headline in a DVD mag's review for either the 525 or 626 proclaiming "Lip Sync Problems No More!" or words to that effect. They ended up with one of the most reliable range of players on the market (and still have).
    The two test discs I used when I went for a demo of these machines were the two most notorious offenders of the day, "Lost In Space" and "Lock Stock and Two Smoking Barrels" which displayed some horrendous sync problems, particularly on (from the majors) Panasonic, Toshiba and Sony models. The new Pioneers played them perfectly, proving once and for all the problem was mainly with the machines, not the discs.
    I think I read at the time that it was something to do with flags that occur periodically in the digital bitstream that are used to lock sound to picture. Apparently if a disc was authored with too few of these flags in the stream, then the firmware of most machines had a hard time staying in sync. Something like that anyway... "Lock Stock..." was in fact one of the first discs to be reauthored in connection with this.
    Accordingly, the first player I bought was the Pioneer 626D and for almost five years up until I upgraded to the 757i about a month ago, it played close on 2,000 different discs without a glitch. The only lip sync problem I have ever encountered was on the DTS track of the R1 "Robin Hood: Prince of Thieves" 2 disc set, in the closing section of the movie, but that turned out to be an authoring problem.
