DVD lens cleaner - anybody used one?
Discussion in 'Blu-ray & DVD Players & Recorders' started by skyline32, Sep 13, 2005.
  1. skyline32
    skyline32
    Aug 9, 2004
    75
    Having had no replies from Toshiba on whether it's possible to replace the drive unit on my ailing RD-XS32, as a last resort I thought I might try a lens cleaner to see if that's the problem.
    Has anyone used one of those "furry disc" type cleaners and if so are they any good?
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    I have used a cd lens cleaner, works fine as long as you follow the instructions, ie on mine it first plays track one which has a voice on it telling you to forward to track 3, this takes the brushes over the lens, and then track 3 plays music so you can check if performance has improved. No need to buy a specific dvd cleaner, as most players will also play music cd's.
  3. ad47uk
    ad47uk
    Apr 21, 2005
    749
    +6
    I have only used a CD lens cleaner once in a CD player, but I am not fond of them. I suppose it goes back to the cassette days, when I would not touch a head cleaning cassette and done the job with a cotton bud and isoproanal.
    It is not as easy to do with DVd players, so I tend to leave alone. the only time I will use one of these lens cleaner is when/if I have a problem.
    I have got a DVD player that is about 3 years old now and for 12 months it had been stuck in the corner, I set it up a few days back, to test a DVD and after blowing the cobwebs and dust off the thing, I put the DVD in and it worked.
