DVD jerky and sound out of sync on Artisan
Discussion in 'Computer Components' started by _Dom_, Jul 10, 2005.
  1. _Dom_
    _Dom_
    Feb 20, 2005
    114
    I have an Elonex Artisan which i have hooked up to my Home Cinema amp and TV. A lot of the time when I watch a dvd on it the picture can be jerky - how can I fix this ? Also sometimes the sound is out of sync with the picture - someone told me it was because the sound is being decoded by my amp as well as by the artisan - any ideas on what I can do to resolve this also please ?
    thanks.
    Dom
  2. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Check "Transfer Mode" is DMA and not PIO.
    This is how I did it.
    If you don't know how: System Properties>Hardware>Device Manager>IDE Controllers>Properties>Advanced Settings
    If you have PIO anywhere here, then you should uninstall the controller and reboot. Windows should reinstall with DMA.
    PS If you make a mistake - then as Bart might say "I din't do it!" :oops: .
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Do a search for Jerky and Stutter. Theres volumes of stuff that can be applied to a PC to help alleviate these.
  4. _Dom_
    _Dom_
    Feb 20, 2005
    114
    Kolabere, u are a STAR ! :clap:
    Cheers mate - that has sorted it, the second Primary IDE was set to PIO, now its running at DMA its as good as new. I don't know what the setting does or what the secod Primary controller IS even, but it works !.
    Brill.
    :beer: Cheers !
