dvd is stuck in a Sony DAV SC-6
Discussion in 'Home Cinema Buying & Building' started by ll KP ll, Aug 4, 2005.
  1. ll KP ll
    ll KP ll
    Aug 4, 2005
    3
    A dvd is stuck in my sony dav sc6, when i press eject nothing happens, there is not even a "locked" message. And also the system does not turn off, it just keeps flashing standby and it has to be restarted by turning the mains off then on. How do i take this dvd out?
  2. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,862
    The manual suggests possible overheating or speaker short. Try switching off at the mains & disconnect all speaker connectors. Allow to fully cool down & try with the speakers still disconnected. If it powers up & ejects the disk, reconnect the speakers one at a time & re-test, powering down each time.
  3. mausti
    mausti
    I've got the same problem. Tried disconnecting everything, but still the same problem. Did you find a fix for it in the end?
  4. himdman
    himdman
    See my answer in this post: http://www.avforums.com/forums/showthread.php?t=284304
