DVD in car and stereo headunit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by dextrovert, Mar 21, 2005.
  1. dextrovert
    dextrovert
    this has probably been asked but i can not see it anywhere.
    Is it possible to hook up a DVD and a Stereo head unit or can you only hook it one or the other.
    The reason i am asking is because i wouldn't mind hooking up a DVD set but i want to keep my stereo headunit.
    If its any more informative, i have a Ford Ka.
    cheers
  2. pauldrage
    pauldrage
    Hi.
    if you find somewhere to mount the dvd player (in dash one?)
    then you can mount it, and run the cables into a screen?
    is this what you mean?
    usually i am guessing a dvd player will take power.. and then have av output into a screen (av input). and the screen would take power and sound output with av input.
    A ford ka probably doesnt have enough places for both a dvd player, screen, and headunit?
    If you had a flipout screen dvd (all in one) player you wouldnt need a headunit / stereo as it doubles up.?
  3. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    This is something I am planning to do in my new Zafira. If your Ka unit has an Aux input, you could purchase a dedicated DVD player, mount it somewhere like the glovebox, or under a seat, run stereo out to the head unit and video to a screen - if you get a screen which accepts audio in as well, you could split the audio signal so that you could watch a movie and listen to sound via a headphone connection on the screen itself - CD for the driver, movies for the kids! One option I am looking at is an all-in-one roof mount DVD/flip down screen, with wireless headphones - audio signal also wired back to the HU via aux selection (Sony, VDO, various Korean and US brands do this).
    Alternatively you could go for a high end Kenwood, Pioneer or Alpine which has dual zone capability - with a DVD changer and screen you can dedicate DVD playback via a screen, again with headphone output, and keep the radio or CD for the car speakers. More expensive, but do-able.
