DVD in a SCART 'daisychain'
Discussion in 'Blu-ray & DVD Players & Recorders' started by Supersonic72, Mar 7, 2006.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Hiya..
    I usually lurk in the Plasma forum, but as this is more of a DVD query,
    thought it'd be better in here...
    I've got a chain of devices linked with SCART cables. In order, I have my
    Panny display, linked into my Samsung NTL box, then a Panny VCR then
    last of all, into a Panny RV-31 DVD player.
    I get no picture from the DVD player in this linkup, and the manual does
    mention issues regarding copy protection, which I understand.
    As the DVD player has just one SCART connector, it must go on the end of
    the chain, so can i turn the copy protection or whatever it is, off?
    Failing that, does anyone have a better suggestion, as im manually
    swapping cables over when i need to watch a DVD...
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,149
    +7,095
    Your posting seems to imply that you have a plasma display [ ? ] which i would therefore expect to have more than one scart input.
    Can you not take the DVD player direct into another scart on the Plasma panel?
  3. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    If the VCR has two scart sockets simply plug the DVD player into its AV2 scart.
    The fact you are getting no pic from the DVD has nothing to do with copy protection.
  4. sparky_paul
    sparky_paul
    Jan 12, 2006
    246
    Notts/Lincs border
    +10
    Not sure about yours, but some VCRs will not pass through an RGB signal - it might be worth trying the DVD player with it set to output PAL/CVBS/Composite...
    ...and put up with the inferior picture quality.:thumbsdow
    Apologies if you've already tried this.
  5. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    I might try moving the connections around on the VCR
    The display has one SCART input, which links into the NTL box.
    From there, cable between the NTl box and VCR and finally, from
    the VCR to the DVD...
    With thanks!
  6. maldonian
    maldonian
    Nov 25, 2004
    919
    43
    +91
    Another way is to use a SCART switch. There are various types available ranging from simple automatic ones to fancy ones with remote control and separate input switching for the TV and recorder outputs. There's a selection here from Keene (select Switchboxes on the left side of the page, then Scart). The HSR1000 looks interesting. You could also try Maplin and Lektropacks.
