DVD importers?
Discussion in 'Blu-ray & DVD discs' started by GalacticaActual, Jun 15, 2015.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    Hi all,
    Does anyone still import DVDs and blu rays? if so what company do you use please?
    I am looking at getting a region free uncut ERASER Blu ray but am unsure as who to use.
    Thanks.
  2. mikemag
    mikemag
    Jun 5, 2007
    3,681
    167
    +11,213
    The U.S. Blu, which appears to be uncut, is available for £8.49 plus postage through Amazon.co.uk Marketplace.
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    Is that what I search for? Eraser market place? Do you gave the link?
  4. hippo99
    hippo99
    Feb 29, 2008
    17,150
    163
    +10,284
    If you type in '"Eraser Blu-ray import" into the search on Amazon then it'll usually bring up any marketplace listings selling non-uk discs. Then once you click into the listing, click on "Other Sellers on Amazon" near the top right as the default listing may not be the cheapest/reliable seller.
    eg
    Amazon.co.uk: Buying Choices: Eraser [Blu-ray] [1996] [US Import] [2008]
    The marketplace sellers for import discs I usually go with are allyourmusic, Supermart_USA & moviemars_USA.
    Be careful that moviemars (not sure about the others) also sells UK discs so if importing from them make sure the listing says "import" & "region 1/A disc" or "non-region 2 disc" in the listing. Doesn't apply for Eraser, but useful to remember for future orders.
