DVD image vs HD image
Discussion in 'Plasma TVs Forum' started by PaulBudrow, Mar 31, 2005.
  1. PaulBudrow
    PaulBudrow
    I just hooked up my new prog scan dvd player to my philips plasma. Is DVD image quality slightly less sharp then HD picture? The DVD picture is fabulous but just not as sharp as my HD channels.
    I saw an dvd that converted HD signal. Would that result in a clearer picture?
  2. symphara
    symphara
    Jul 15, 2004
    317
    Switzerland
    +58
    HD resolutions (720p and 1080i) are much higher than the DVD resolution, so naturally the image would appear sharper due to the increased number of pixels. You can't get a HD image from today's regular DVDs, the information isn't there. Upscaling won't produce sharper images. I suggest waiting for Bluray or HD-DVD!
  3. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i've tried superbit and found the difference neglible...
  5. symphara
    symphara
    Jul 15, 2004
    317
    Switzerland
    +58
    Superbit DVDs are at the same resolution as regular DVDs. The bitrate is allegedly higher than with regular DVDs (although since they always include both Dolby Digital and DTS soundtracks I doubt there's much difference), resulting not in a sharper picture but theoretically fewer compression artifacts. I have a couple of Superbit DVDs (Spiderman and Vertical Limit) and I can safely say there's no difference in terms of image quality compared to the regulars (I do like the DTS soundtrack however, which is why I bought them).
    The only real alternative I know of on DVD are WMV-HD movies, which are in true HD format. However, this is not MPEG 2 and you'll need a computer to play them.
