DVD help
Discussion in 'Blu-ray & DVD Players & Recorders' started by benjaminL14, Mar 14, 2003.
  1. benjaminL14
    benjaminL14
    :hiya: can anyone gimmie a hand, i didnt know where to post this message, i use a ps2 for a dvd player and i can only connect it to my VCR and it has all these anti taping methods on the screen, im not trying to copy em i just want to watch my dvd's so can anyone help me out, plz reply via email - benji7_11@HOTMAIL.COM THANKS:clap: :smashin:
  2. CARLOS
    CARLOS
    Feb 11, 2001
    5,996
    WEST MIDLANDS
    +1,224
    Hi benjaminL14
    Welcome to the forums
    As for your question unfortunately you can`t loop a dvd through the VCR as it triggers the Macrovision copy protection (thinks you are trying to copy the disc).
    The only way is a direct connection or if you don`t have enough sockets on your TV get a scart switching unit which are available from about £10.
  3. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    If you dont want to copy them why do you want to run the DVD through your video?
  4. slenderdeer
    slenderdeer
    You can if you have the right equipment run a dvd via computer dvd player then through TV out on you video card assuming you have it, most do now. Then use a program called TVtool, theres an option to disable macrovison
