DVD Headphone/Microphone slot???
Discussion in 'Headphones, Earphones & Portable Music' started by GeeMan1973, Dec 22, 2004.
  1. GeeMan1973
    GeeMan1973
    Hi need some help desperately...
    Rather stupidly - i've just bought a bargain DivX DVD from Smiths for £30. Thinking it had a headphone socket on the front of the pic. Turns out its a microphone slot.
    No mention anywhere in the manual of using headphones. As i'm nearly deaf and require headphones and subtitles to watch films - im in a pickle.
    Someone mentioned the possibility of buying a headphone amp - that plugs into my dvd and headphones into that.
    Can anyone suggest a cheap way of allowing me to connect my headphones to my dvd? And i do mean cheap - dont want to spend £150..
    The DVD player only cost £30 and the headphones were £20.,,
    any help appreciated... thanks
