Dvd HDD Recorder
S
Stevey
I am looking for a HDD recorder that has any size drive, it doesn't matter because I will put in a 120gb or bigger drive in the future rememebering the 137gb limit!
I want the HDD recorder so I can digitally record tv programs off my tv, a bit like sky +
It would be nice if it has a dvd drive in it to play dvds, it is not neccessary for it to be able to record onto dvd discs. A component output is really required to connect to my 51WH36 toshiba RPTV
I also want it to be possible to record a seperate stream i.e. at night time be possible to record my camera system in digital quality.
Is this possible? If so what makes/models out there meet my needs? Money is no object atm.
Please help me!
Thanks in advance:smashin:
richard plumb
get a tivo off ebay or tivoland.com
SCART feed for recording sky, separate rf feed which you can tune into your CCTV.
RGB-component converter to connect to your plasma
Takes any sizes of hard drive (I currently have 2x120GB drives in mine). you can even connect it up to a network and control it remotely
S
Stevey
btw I use a RPTV but thanks. I could use scart instead.....
kenfowler3966
Don't assume you can replace the drive with a larger one, it is impossible in the panasonics as the unit still only sees the original size it was designed for no mattter what you install. A dedicated core of people have tried to get around it but no-one has succeded, and I expect this will be the same with most of the other hard drive/dvd recorders. The only equipment that can definately be upgraded are sky+ and tivo
65-inch LG C1 Review coming soon to AVForums
