DVD/HD Recorder with Set top Box Control
Discussion in 'Blu-ray & DVD Players & Recorders' started by bellbrie, Mar 15, 2006.
  1. bellbrie
    bellbrie
    May 8, 2003
    23
    Hi all,
    I have had a trawl through the forums but have not seen an answer to this, so perhaps someone can help me.
    My Dad is looking for a DVD/HD recorder and had seen the Toshiba RD-XS24 that he liked.
    Looking at the spec on this, I can't see any way for this to control a cable, satelite or freeview box. Is this true? If so, what other DVD/HD recorders can do this?
    Thanks,
    b.
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
  3. bellbrie
    bellbrie
    May 8, 2003
    23
    Thanks for the reply Phil.
    It doesn't look like th eToshibas have thi s- so will have to look at another make.
    Cheers.
  4. 38H21543
    38H21543
    Jan 6, 2004
    195
    +8
  5. bellbrie
    bellbrie
    May 8, 2003
    23
    OK - thanks for that - I have had a look at the link and see what you mean. I downloaded the manual for the XS24 and the connections diagram in the manual does not have an IR sender or G-Link socket.
    I guess I'll have to trawl through them one by one.
    b.
