DVD/HD Recorder with HDMI??
Discussion in 'Blu-ray & DVD Players & Recorders' started by kop1973, Aug 15, 2005.
  1. kop1973
    kop1973
    Aug 2, 2005
    168
    +3
    Money no object DVD/HD recorder....is there any good ones coming out or anything I can buy now??
  2. spannersuk
    spannersuk
    To add to the question above – and this may be a dumb question – what is the benefit of HDMI on a non Hi Def DVD player surely you’ll get the same resolution as using a scart?
  3. Mark_a
    Mark_a
    May 27, 2005
    2,870
    +485
    Top o' the line Pioneer DVR-920H-S has HDMI out, and a 250Gb HDD, but it's hovering around the grand mark last I checked. I believe Samsung are about to release, if not already, an HDMI equiped machine. You can bet the others won't be far behind.
    As for is it better than a scart? Well, it should be as scart is analogue, so it's had to have been through a D-A converter. As HDMI is digital, then it won't. But all things being equal you won't see a vast improvement, but there will be some. It would become much more obvious the larger your display, so if you're connecting it to a projector then HDMI would be definitely preferable. On a 28" CRT you'd probably be hard pushed to tell the difference. Not that I know of any 28" CRT TVs with HDMI inputs. By and large they tend to be on HiDef ready displays.
    Regards
    Mark
  4. Topgunn
    Topgunn
    Dec 2, 2004
    44
    Lg Rh7900h
  5. gurivan
    gurivan
    May 8, 2005
    9
    Kiev
    Samsung DVD-HR725 (DVD-RAM/RW/R HDD160GB HDMI)
    Samsung DVD-VR325 (DVD-RAM/RW/R VHS HDMI)
