DVD / HD Recorder (DMR-E95 ??)
Discussion in 'Blu-ray & DVD Players & Recorders' started by milanlad, Mar 7, 2005.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I'm just about to buy a DVD / Hard Disk recorder but just need a final bit of help in deciding.
    Number one on my list is the Panny DMR-E95.
    I need lots of hard drive space, recording flexibility, good quality, good connection options, etc.
    One thing I don't know about this model is how quiet it is? Does it have a cooling fan? Does the hard drive make much noise?
    Also, are there any regular problems with failed recordings on the hard drive?
    Which DVD/HD do other people are in the top 3?
    I'm going for DVD-RAM cause I've already had a DMR-E30.
    All help appreciated....
  2. TobyW
    TobyW
    Jan 6, 2005
    157
    Australia
    +3
    On my E85 there is just a momentary noise at start-up, like a head access or something. Otherwise it's completely silent. I can't tell that the fan is running, unless I go and look or put my hand over it.
    If I was buying now, I would wait for the new one with better resolution in LP mode.
