Dvd Hd Query
Discussion in 'General TV Discussions Forum' started by wardster, Jun 16, 2005.
  1. wardster
    wardster
    Just about to buy an HD LCD and HD DVD player - just got one query...
    Will the picture of a standard DVD movie played over HD DVD to HD LCD be noticeably better?
    or is this only relevant when you get a HD DVD movie etc?
    Many Thanks
  2. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Where are you getting an HD DVD player from, thought they werent out till end of year at earliest. What make and model is it. :confused:
  3. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I think he means a DVD player that is HD enabled by upscaling the picture of normal DVDs to 720 or 1080 through HDMI.
    (ie Denon 2910 or 3910)
    To answerwardsters Q. Yes you will see a big difference in picture quality at 1080i or even 720p. Just make sure to test it all on the best possibel DVD disks that are out there. I recomend:
    Fifth Element R1 Superbit. Spiderman 2 R2 (NTSC, Jp) Superbit.
    Terminator 2 Extreme Edition R1. This DVD was made from the HD source and has a flawless picture.
    There are many more good DVDs out there that have near HD quality picture through an upsacling DVD player and HD screen.
  4. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Had a hunch thats what was meant. Like AML said, you should notice quite a difference. Although my HD945 is a the budget end of hdmi players the PQ through hdmi is superb. There is the odd old dvd thats a bit naff but the vast majority play wit a new lease of life. :D
  5. GJD
    GJD
    Sep 23, 2002
    295
    +8
    Will something like PowerDVD upscale standard DVD's to 720p or 1080i if your PC and LCD is up to it? Just weighing up whether to plump for a Samsung HDMI DVD player to go with my LE26R41B..
  6. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +180
    Gfx cards usually only allow output at 480p. Things like AnyDVD circumvent this and you can then use ffdshow to upscale.
  7. GJD
    GJD
    Sep 23, 2002
    295
    +8
    Cor this Hi-def business is confusing! Thanks anyway though.. will go and read up. The WMHD demos I've seen look better than 480p though.
