dvd hard disc to dvd hard disc
Discussion in 'Blu-ray & DVD Players & Recorders' started by ondrewskeo, Feb 22, 2013.
  1. ondrewskeo
    ondrewskeo
    Feb 22, 2013
    23
    3
    Hello, my samsung dvd recorder (SH875M)has stopped recording programmes from the hard drive to a blank disc. Ive got a new samsung dvd recorder (SH897M) and would like to transfer programmes from the old recorder hdd to the new one. what connection leads would i need to achieve this in the best possible quality
    thanks
  2. formbypc
    formbypc
    Oct 9, 2010
    1,579
    63
    +105
    What inputs and outputs do they each have?
  3. ondrewskeo
    ondrewskeo
    Feb 22, 2013
    23
    3
    both pretty much the same
    2 scarts (av1, av2)
    HDMI out
    Component out (PR, PB , Y)
    AV out ( red white yellow)
    Digital audio out- optical
    RF In ,RF out
  4. ondrewskeo
    ondrewskeo
    Feb 22, 2013
    23
    3
    Sorry also on front of both
    AV input 1
    DV input
    USB Host
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,132
    +7,049
    A scart connection is your only option... but you need to ensure that you connect via RGB to obtain the best quality.
    The '897 has RGB input capability
    Connect a scart ( must be a fully wired type to obtain RGB) between AV1 of the '875 to AV2 of the '897.
    Ensure that RGB is selected in the 897's AV2 input settings.
  6. ondrewskeo
    ondrewskeo
    Feb 22, 2013
    23
    3
    Hello, finally got around to trying this.Connected as above but whn i press record on the '897 it comes up record on the display for about 1/10th of a second and then stops. Anyone help please? Gavtect?
    thanks
  7. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Have you already pressed play on the source machine before pressing record on the target? Some machines cancel recording if they don't detect an incoming signal. So, if the source DVD recorder is not already playing something - or not feeding a signal out via scart from its own internal tuner - then the target DVDR picks up the lack of signal and immediately cancels the recording.
    Either ensure the source machine is playing back items from its hard drive before pressing record on the target - or connect the source machine to the TV aerial so that it is receiving - and more importantly outputting via its scart output - a valid signal that the target machine can detect.
  8. ondrewskeo
    ondrewskeo
    Feb 22, 2013
    23
    3
    Yes the source machine is playing fine with a good picture when i press the record button however i have no tv ariel connected to the source machine, Is this neccessary?
  9. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Only if you wanted to ensure that the target machine was receiving a good signal before you started recording. As you've already proved that this is the case - because you can see the signal being sent to it from the hard drive recordings on the source machine - this isn't the issue.
