dvd hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by sweetnut, Mar 4, 2001.
  1. sweetnut
    sweetnut
    Can anyone supply me with the hack for a Goodmans gdvd100 player to enable multi-region.Currently region 2 only. Thanks.
  2. RMCF
    RMCF
    Aug 24, 2000
    7,571
    +785
    First turn the player on. Then type these in with NO DISC in machine.
    1)SETUP
    2)STEP
    3)PREV
    4)NEXT
    A hidden menu will appear. Set the REGION CODE to any one of your choice or change to BYPASS for mult-region.
    If it doesn't work 1st time - try it a few times.
