Dvd Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by nuker, Sep 17, 2004.
  1. nuker
    nuker
    Sep 11, 2004
    24
    4
    CAN ANYONE HELP, WON A DVD PLAYER FROM DAILY MAIL NEED IT TO BE MULTI REGION IT'S A ACOUSTIC SOLUTIONS TE-118A.
    HELP!!!!!!!!!!!!!!!!!!!!!!!! :lease:
  2. Richard Jolley
    Richard Jolley
    I see you have the same problem with your TE-118A DVD I have! Did you get any response?
  3. macks1966
    macks1966
    Mar 13, 2005
    14
    3
    +5
    erm found this, it works too :) :) :)
    Open DVD tray
    key 9 7 3 5
    On menu use right, then up, up to select Region 0
    Select
    Exit Setup
  4. spuddy01
    spuddy01
    Aug 5, 2005
    334
    Dromcollogher,Co Limerick
    +23
    Hey thanks for that Hack just tried on the Acoustic solutions portable dvd-222 &
    it works a treat :thumbsup:
  5. eas4uk
    eas4uk
    Oct 19, 2003
    1,542
    Coventry
    +88
    How did you get this to work on this player - Im trying now and no joy - cant get the menu up at all - the hand signal comes up then it just goes back to saying "open"
  6. Hackeroonie
    Hackeroonie
    Dec 2, 2005
    252
    Cardiff...Wales
    +18
    Eas4uk
    Ignore the Hand Signal !!...I get the Same on Mine...but after 9 7 3 5 is entered the Region Select Screen Appears
    The Region Screen also Appears if you leave the Tray Closed...so you can do it that way..but if you do it you then need to select Exit Setup to store the Hack
    There is NO Hand signal if you Apply it with the Tray Closed
    Here is that Version of the Hack, I have Checked it works on My AS DVD222
    Turn Player On and wait for No Disk to Appear
    Using Remote Control Press 9 7 3 5
    Region & Software Version Appears On Screen
    Using Remote Control Left Button Scroll Across to Region Selection and use the Up & Down Button to Select Required Region ( 0 is Region Free) and Press Play / Enter Button on Remote Control
    Using Remote Control Scroll down to Exit SetUp & Press Play / Enter Button on Remote Control
    Hope this Helps
    Hackeroonie
  7. eas4uk
    eas4uk
    Oct 19, 2003
    1,542
    Coventry
    +88
    Thanks for the reply hackeroonie
    However when I enter the code 9735 no region select screen appears - nothing at all - the hand signal is there but no new menu screen - is there anything else I need to do beforehand? Bought two of these from Argos earlier after checking they were "hackable" and they are flying off to Cyprus tomorrow (xmas pressies) so really need to try and get it sorted asap - very frustrating :(
