DVD glitches!!! :(
Discussion in 'Movie Forum' started by twist3r, Sep 18, 2003.
  1. twist3r
    twist3r
    Hello
    Im fairly new to DVD and im not exactly impressed so far! I have recently bought a few DVD's, namely xXx and Die Another Day. Both of these have points in them where the picture freezes and I loose audio for a few secs before carrying on. This always happens in the same point of the film and it happens if I play them on my DVD player, My PC or my Dad's PC.
    Because it happens on multiple players then I have come to the conclusion that the disc's have faults with them. I also recall this happening on other DVD's I have. Yet other's are fine.
    Is this a case of faulty discs? The player I have is only a cheap one, would this not happen with a better quality player?
    The whole point of DVD is to have a completley faultless film isn't it?
    This isn't a common thing is it? I hope not!
  2. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    I'm not sure. I've noticed a few glitches recently, although they aren't repeatable. When I watched FOTR EE R1 a few weeks ago it glitched 3 or 4 times, picture froze and sound dropped, for about 0.5 seconds then carried on.
    I watched some of Gladiator last night and it did the same thing. Only thing they had in common is that I was using DTS audio. I haven't noticed problems with any other DVDs that weren't obviously scratched.
  3. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    Does this happen just once about half way through the movie?
  4. twist3r
    twist3r
    Your right it does! Only once and always at the same point in the movie, approx half way through, give or take 10 mins or so. I know on xXx its right after the avalanche.
    Do you know why it happens? :)
  5. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    Errr,
    Its not when the dvd changes from one layer to another is it ?
    Ghidorah
  6. paul1672
    paul1672
    Jul 31, 2003
    2,558
    71
    norfolk
    +37
    it's a common thing due to the disc being duel layered.
    i'm sure others will confirm this but imo the discs aren't faulty.
    it's perfectly normal and the pause varies in length depending on dvd player.
    not all discs are dual layered which is why you haven't always experienced this.
    hope this helps.
    and this is only my opinion.
  7. twist3r
    twist3r
    Ah right that explains alot! :)
    Actually, it always happens right at the end of a scene, or right at the start of another scene so at least they put them in at decent points and not right in the middle of scene's !
    Thanks for the info :)
  8. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    Hi There,
    If you buy some of the early dvds they just put the change over any where. It was awful. Right in the middle of someone speaking it would just stop AHHHHHHHHHHHH
    Glad that seems to be that:clap:
    Ghidorah
  9. nathan_silly
    nathan_silly
    Where Eagles Dare was a bad layer change- half way through a sentance.
    Although it layer changes don't bother me (takes about 1/4 to 1/2 second to change) I can't understand why they didn't have the change at a end of a scene.
  10. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I concur! :smashin: This is definitely a layer change point... they are a necessary evil I suppose, and dvd producers do try and put them in the most unobtrusive place.
    Also, some dvd players handle them better than others I have noticed... :rolleyes:
  11. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    Yes
    My old Sony 725 was not that good at the change, but with my Harmon kardon DVD25 you hardly notice at all
    Plus I think the discs are better now
    Ghidorah
  12. DpM
    DpM
    Jul 15, 2003
    4,295
    High Wycombe, UK
    +833
    Funny that you should say your dvd 25 is quicker than the Sony Ghidorah, I found that my old samsung 709 is quicker than my dvd 25. But most importantley the quality is much better.:rotfl:
  13. NoelStar
    NoelStar
    it sounds like the layer change to me
    can you believe it most cheap players you dont notice it but
    or for example buy sony or pioneer and you will notice nearly a 2 second freeze during layer change
    i spoke to sony and they said they all do it
    it ****** me off at first but im trying to get use to it and on my pioneer its a pretty quick layer change
    but ive got a few cheap players that you wont even notice it during a film:eek:
  14. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    always notice it on my tosh 210 but have never noticed on my PC, and ive watched most of my dvds on a PC:cool:
