DVD Feature request: resume for more than 1 dvd
Discussion in 'Arcam Owners' Forum' started by cybersoga, Oct 19, 2004.
Tags:
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    My old dvd player would remember where I left off for more than one disc - so I could watch a bit of a TV series, watch a movie, and then put the tv series disc back in and carry on where I left off. My arcam does have resume, but only for one disc. Would it be possible in a future software update to allow resuming of more than one disc?
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    On my DV88+ I just use the bookmark (MEM) to set a resume point for disks I haven't finished watching. When I pop the disk back in I select the bookmark and resume from there.
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Thanks for the tip!
  4. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Even if it proves too costly to implement bookmarks for more than one DVD, at least the ones memorized should be kept in non-volatile memory. If you are watching a movie and have to go out or simply go to sleep, or attend to other pressing tasks it makes no sense that you cannot power off the DVD and resume the film some hours after. Also you may have a visit, and play a CD during the conversation, and return to the film when she leaves!!
    This is no gadget request. It a real life need. And it is available in £150 players.
  5. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    If I press stop and turn the DVD player off, then turn it back on it does start where it left off. It only clears that data when I take the disc out. My old Sony used to hold the data even if I took the disc out unless I pressed stop twice before ejecting it.
  6. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    So, the setting is stored in non-volatile memory. That is good. The problem seems to lie in that the "OPEN" Function is used to clear those settings. However the manual says "(until the disc is ejected or the player reset)".
    In that case I suggest that they be cleared manually using the CLEAR button, instead of the open function.
