DVD Editing
Leeray3
Right here goes.
I have read loads of threads on this but am still not too sure so this is what I want to do.
I want to record from digital tv to my DVD Recorder (Using RW)
I then put this disc into my PC and edit.
Once I'm finished I want to put this back onto DVD (either + or - R).
It's as simple as that.
The final DVD must be at the highest quality and be able to play in any DVD player or players that except + or - R discs.
Is this possible and what would be good software for this.
I only need basic editing software but image quality and sound quality must be of the highest.
MarkE19
Try this:
Ulead Video Studio 7
Robust VR Support
VideoStudio 7 is the first complete video editing software to fully support the DVD –VR and DVD +RW Video Recording formats. If you own a camcorder that records to DVD or DVD set top recorders, you now have a way to capture, edit (directly on disc) and save video in the VR format.
Its available direct from Ulead for £51.72 but almost certainly cheaper from an online retailer such as Dabs.com or Ebuyer.co.uk
Mark.
Leeray3
I have now learned that this software does not work with DVDs that has audio recorded in AC-3.
Is it worth waiting for the fix to this or is there any other software that I can use?
Also does anyone know if I can change the audio format that I record in. My Recorder is the Philips 880 (Don't laugh!!)
I have looked at the settings and can't seem to find a way of changing this.
