DVD dual layer question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nemesis635, Oct 29, 2005.
  1. Nemesis635
    Nemesis635
    I have a DVD +/- R/RW drive.
    can i record onto DVD R+ dual layer media.
    I want to record up to 8GB.
    Many thanks
  2. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    No you can only burn dual layer with a suitable dual layer recorder
  3. Nemesis635
    Nemesis635
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Don't you think you should have asked what make and model number the drive is?
    There are loads of "+/- R/RW" drives that can write +R DL discs.
  5. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    I assumed from the description given that it wasn't a dual-layer burner, as they are clearly labelled as such
  6. steve k
    steve k
    Apr 15, 2001
    714
    Birmingham
    +53
    What burner do you have Nemesis
