DVD drive not working
Discussion in 'Desktop & Laptop Computers Forum' started by Steve Bate, Jun 3, 2005.
  1. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Any ideas? The DVD drive in one of my PC's doesn't seem to recognise anything anymore, if I put any type of disk in it it spins up but then does nothing else. If I check device properties it says it's working properly but I cannot read any type of disk, data, CD or DVD.
    I've double checked it's not locked, disabled it reregistered the drivers but nada :confused:
    Steve
  2. DaveP
    DaveP
    Have you installed InCD? It killed mine a while back.
    If not, you could delete it from Device Manager and let it re-install it again.
    Dave
  3. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    The only software I've put on it recently was the upgrade for TT2. I've tried deleting from Device Mgr and it re-istalls itself but still doesn't "see" any info on the disks.
    Steve
  4. R2D2
    R2D2
    you could try pushing in the IDE cables to see if they have come loose
