DVD Disc cleaners
Discussion in 'Movie Forum' started by Miles, Sep 2, 2004.
  1. Miles
    Miles
    can anyone recommend a good DVD disc cleaner? My Panny HS2 seems to be rejecting more discs than normal just lately and was hoping that a clean would be worth doing before looking at replacement parts :rolleyes:
  2. FoxyMulder
    FoxyMulder
    Allsop laser lens cleaner which works a treat and doesnt use messy liquids.
  3. Rambo John J
    Rambo John J
    Aug 11, 2000
    3,736
    Hanoi Hilton
    +968
    if its really bad and something like the allsop doesn't sort it (I've got one too, good enough for me :smashin: ) you may need to pop the bonnet and physically clean the lens yourself. I tend to do this myself as it takes 5 minutes and isn't worth the £30 I was offered by a dealer to do it, but I've only had to do that on my first player anyway, which is about 7 years old now. I'd go with the allsop first though as it usually does the trick no worries
  4. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Allsop laser lens cleaner, is this item only available from the US?
  5. eas4uk
    eas4uk
    Oct 19, 2003
    1,508
    Coventry
    +81
    The BIB radial cleaners are what I use - one spray per disc and they are great... If the disc is scratched BIB also do CD restorer polish which works very well on DVDs - What Hi-Fi even praised it...
    I can only find one place online which sells the products though... link below...
    Woolworths do stock some of their range so it may be worth a look in there
    http://www.kneesnet.co.uk/cgi/sh000...VD___CD_Cleaning_System_1812.html#a1654#a1654
  6. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    How does CD restorer polish work? I've got a copy of the Bourne Identity with the most innocous looking scratch, but my DVD player pauses on it. Would a restorer work?
  7. eas4uk
    eas4uk
    Oct 19, 2003
    1,508
    Coventry
    +81
    Im not quite sure - I would think it fills the scratch so that the laser doesn't refract in the wrong direction? Im sure someone will now...
    The polish doesn't work on seriously big scratches though... If you've got a big scratch there are some shops that can fix these for a couple of quid... Usually the more discs you get done at a time the cheaper, per disc, it is... The disc does come back basically brand new though.
    www.fixmydisc.co.uk
    http://www.repairmydisc.co.uk
    www.perfectplay.co.uk
  8. FiggyD
    FiggyD
    Jul 2, 2003
    1,270
    38
    Greenwich
    Nail polish remover. :) Works a treat.
  9. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    If you just want to clean your discs.. I use baby wet wipes followed by one of those microcloths (like the oakley sunglasses bag material) to wipe clean... works a treat.. discs come out spotless..
    Matt
